Based on REST principles, the TrendMiner Data Sources API endpoints provide access to data source configuration and operations related to synchronization and requesting data from sources.
1. Authentication
When performing actions authenticated as a client, they will belong to service-account-CLIENTID.
1.1. Creating a new client
1.2.1. For your client
  • Your client ID
  • Your client secret (can be obtained in ConfigHub)
Request
curl --request POST \
Response
200 OK
  "expires_in": 300,
  "refresh_expires_in": 0,
  "token_type": "Bearer",
  "scope": "email profile"
  1. The access token is to be used in every request towards our services (see example below). A new token needs to be fetched when the token expires after 5 minutes.
1.2.2. For a specific user
To retrieve a token to authenticate as a specific user, you will need:
  • Your client ID
  • The user’s username
  • The user’s password
A token is requested from the token endpoint of the authentication service.
Request
--data grant_type=password \
--data client_secret=YOUR_CLIENT_SECRET \
--data username=USERNAME \
--data password=PASSWORD
Response
200 OK
  "refresh_token": "eyJhbGciOiJIUzI1NiIsInR5cCIgOiAiSldUIiwia2lkIiA6ICI0M2U1YR...", (2)
  "expires_in": 300,
  "refresh_expires_in": 1800,
  2. The refresh token can be used to retrieve a new access token for the same session
Using the refresh token
The refresh token can be used to retrieve a new access token for the same session:
Request
--data grant_type=refresh_token \
--data refresh_token=REFRESH_TOKEN
=== Doing a request with an access token
Example request with access token
curl --request GET \
  --url 'https://YOUR_DOMAIN/ds/[any api]' \
2. Resources
2.1. Asset
2.1.1. Get a specific asset denoted by the provided assetId
GET /datasources/{id}/assets/{assetId}
Parameters
Type
Name
Description
Schema
Path required
id
The identifier of the datasource
UUID
Path required
assetId
The identifier of the asset
String
Responses
HTTP Code
Description
Schema
200
Ok
AssetRepresentation
404
The resource was not found
AssetRepresentation
501
Datasource does not support 'ASSET' capability
AssetRepresentation
Produces
  • application/json
2.1.2. Get assets by ids from the tree
POST /datasources/{id}/assets
Parameters
Type
Name
Description
Schema
Path required
id
UUID
Body
required
string
[string]
Responses
HTTP Code
Description
Schema
200
Ok
List[[AssetRepresentation]]
404
501
Produces
  • application/json
2.1.3. Get all root assets from the tree
Parameters
Type
Name
Description
Schema
Path required
id
UUID
Responses
HTTP Code
Description
Schema
200
Ok
404
Produces
  • application/json
2.2. Configuration
2.2.1. Get the full list of configuration items
GET /configurations
Parameters
Type
Name
Description
Schema
Query
optional
page
Zero-based page index (0..N)
Query
optional
size
The size of the page to be returned
Query
optional
sort
Sorting criteria in the format: property,(asc
desc). Default sort order is ascending. Multiple sort criteria are supported.
Responses
HTTP Code
Description
Schema
200
Ok
PagedModelConfigurationItemRepresentation
Produces
  • application/json
  • application/hal+json
2.2.2. Get a configuration item by name
GET /configurations/{name}
Parameters
Type
Name
Description
Schema
Path required
name
Name of the configuration item to return
String
Responses
HTTP Code
Description
Schema
200
Ok
Produces
  • application/json
2.2.3. Update a configuration item.
PUT /configurations/{name}
Parameters
Type
Name
Description
Schema
Path required
name
Name of the configuration item to update
String
Query
required
value
New value to update
Responses
HTTP Code
Description
Schema
200
Successfully updated configuration item
404
The configuration item was not found
204
No Content
2.3. Connectors
2.3.1. Create a new connector.
POST /connectors
Parameters
Type
Name
Description
Schema
Body
required
ConnectorModel
[ConnectorModel]
Responses
HTTP Code
Description
Schema
400
Bad Request
ConnectorRepresentation
201
Created
Produces
  • application/json
2.3.2. Delete a connector.
DELETE /connectors/{id}
Parameters
Type
Name
Description
Schema
Path required
id
The identifier of the connector
UUID
Responses
HTTP Code
Description
Schema
204
No content
404
202
Accepted
2.3.3. Get a list of all connectors
GET /connectors
Parameters
Type
Name
Description
Schema
Query
optional
page
Query
optional
size
Query
optional
sort
Responses
HTTP Code
Description
Schema
200
Ok
PagedModelConnectorRepresentation
Produces
  • application/json
2.3.4. Get the connector for the specified identifier.
GET /connectors/{id}
Parameters
Type
Name
Description
Schema
Path required
id
UUID
Responses
HTTP Code
Description
Schema
200
Ok
404
Produces
  • application/json
2.3.5. Get the version of a connector.
GET /connectors/{id}/version
Parameters
Type
Name
Description
Schema
Path required
id
UUID
Responses
HTTP Code
Description
Schema
200
Ok
VersionInfo
404
VersionInfo
Produces
  • application/json
2.3.6. Get a list of all datasources which belong to a connector
GET /connectors/datasources
Parameters
Type
Name
Description
Schema
Query
optional
page
Query
optional
size
Query
optional
sort
Responses
HTTP Code
Description
Schema
200
Ok
PagedModelDatasourceRepresentation
Produces
  • application/json
2.3.7. Synchronizes a connector.
POST /connectors/{id}/sync
Parameters
Type
Name
Description
Schema
Path required
id
UUID
Responses
HTTP Code
Description
Schema
200
Ok
404
202
Accepted
2.3.8. Test connector connection.
POST /connectors/{id}/test
Parameters
Type
Name
Description
Schema
Path required
id
UUID
Responses
HTTP Code
Description
Schema
200
Ok
ConnectionTest
404
ConnectionTest
Produces
  • application/json
2.3.9. Update a connector.
PUT /connectors/{id}
Parameters
Type
Name
Description
Schema
Path required
id
UUID
Body
required
ConnectorModel
[ConnectorModel]
Responses
HTTP Code
Description
Schema
200
Ok
400
Bad Request
404
Produces
  • application/json
2.4. Context
2.4.1. Returns a list of changed context items in the source system as well as the type of change that happened.
GET /datasources/{id}/context/changes
Parameters
Type
Name
Description
Schema
Path required
id
UUID
Query
required
since
The start date of the query period. Internet DateTime format, see RFC3339 e.g.: '2012-01-01T00:00:00Z’.
Query
optional
page
The page to get. This is a cookie that is returned by a previous call to the /changes endpoint.
Query
optional
size
The page size
Responses
HTTP Code
Description
Schema
200
Ok
CursorPagedResourcesContextChange
501
Datasource does not support 'CONTEXT' capability
404
Produces
  • application/json
2.4.2. Get a list of available context fields for the given datasource
GET /datasources/{id}/context/field
Parameters
Type
Name
Description
Schema
Path required
id
UUID
Query
optional
page
Query
optional
size
Query
optional
sort
Responses
HTTP Code
Description
Schema
200
Ok
PagedModelFieldRepresentation
501
404
Produces
  • application/json
2.4.3. Get a context item for the given datasource and context id.
GET /datasources/{id}/context/{contextItemId}
Parameters
Type
Name
Description
Schema
Path required
id
UUID
Path required
contextItemId
The identifier of the contextItem
String
Responses
HTTP Code
Description
Schema
200
Ok
ContextItemRepresentation
501
404
Produces
  • application/json
2.4.4. Get a list of context items for the given datasource
Parameters
Type
Name
Description
Schema
Path required
id
UUID
Query
required
startDate
Query
required
endDate
The end date of the query period. Internet DateTime format, see RFC3339 e.g.: '2012-01-01T00:00:00Z’.
Query
optional
createdAfter
Returned context items need to be created after this date. Internet DateTime format, see RFC3339 e.g.: '2012-01-01T00:00:00Z’.
Query
optional
page
Query
optional
size
Query
optional
sort
Responses
HTTP Code
Description
Schema
200
Ok
PagedModelContextItemRepresentation
501
404
Produces
  • application/json
2.4.5. Get a list of context items for the given datasource and context identifiers.
POST /datasources/{id}/context
Parameters
Type
Name
Description
Schema
Path required
id
UUID
Body
required
string
[string]
Responses
HTTP Code
Description
Schema
200
Ok
List[[ContextItemRepresentation]]
501
404
Produces
  • application/json
2.4.6. Get a list of available context types for the given datasource
GET /datasources/{id}/context/type
Parameters
Type
Name
Description
Schema
Path required
id
UUID
Query
optional
page
Query
optional
size
Query
optional
sort
Responses
HTTP Code
Description
Schema
200
Ok
PagedModelContextTypeRepresentation
501
404
Produces
  • application/json
2.4.7. Get a list of available context workflows for the given datasource
GET /datasources/{id}/context/workflow
Parameters
Type
Name
Description
Schema
Path required
id
UUID
Query
optional
page
Query
optional
size
Query
optional
sort
Responses
HTTP Code
Description
Schema
200
Ok
PagedModelWorkflowRepresentation
501
404
Produces
  • application/json
2.5. Datasources
2.5.1. Create a new datasource.
POST /datasources
Parameters
Type
Name
Description
Schema
Body
required
DatasourceModel
[DatasourceModel]
Responses
HTTP Code
Description
Schema
400
Bad Request
404
201
Created
Produces
  • application/json
2.5.2. Delete a datasource.
DELETE /datasources/{id}
Parameters
Type
Name
Description
Schema
Path required
id
UUID
Responses
HTTP Code
Description
Schema
204
No content
404
202
Accepted
2.5.3. Get the datasource for the specified identifier.
Parameters
Type
Name
Description
Schema
Path required
id
UUID
Responses
HTTP Code
Description
Schema
200
Ok
404
Produces
  • application/json
2.5.4. Get a list of all datasources
GET /datasources
Parameters
Type
Name
Description
Schema
Query
optional
type
The datasource type
Query
optional
capabilityType
The capability type
Query
optional
page
Query
optional
size
Query
optional
sort
Responses
HTTP Code
Description
Schema
200
Ok
Produces
  • application/json
2.5.5. Search datasources
GET /datasources/search
Parameters
Type
Name
Description
Schema
Query
optional
types
The datasource type
Query
optional
capabilityTypes
The capability type
Query
optional
name
The name of the datasource
Query
optional
page
Query
optional
size
Query
optional
sort
Responses
HTTP Code
Description
Schema
200
Ok
Produces
  • application/json
2.5.6. Synchronizes datasource time series definitions.
POST /datasources/{id}/sync
Parameters
Type
Name
Description
Schema
Path required
id
UUID
Responses
HTTP Code
Description
Schema
200
Ok
404
202
Accepted
2.5.7. Test datasource connection status.
POST /datasources/test
Parameters
Type
Name
Description
Schema
Body
required
DatasourceModel
[DatasourceModel]
Responses
HTTP Code
Description
Schema
200
Ok
ConnectionStatus
2.5.8. Test datasource connection status.
POST /datasources/{id}/test
Parameters
Type
Name
Description
Schema
Path required
id
UUID
Responses
HTTP Code
Description
Schema
200
Ok
ConnectionStatus
404
ConnectionStatus
2.5.9. Update a datasource.
PUT /datasources/{id}
Parameters
Type
Name
Description
Schema
Path required
id
UUID
Body
required
DatasourceModel
[DatasourceModel]
Responses
HTTP Code
Description
Schema
200
Ok
400
Bad Request
404
Produces
  • application/json
2.6. Event
2.6.1. Write an event back to the source.
POST /datasources/{id}/events/event
Parameters
Type
Name
Description
Schema
Path required
id
UUID
Body
required
EventModel
[EventModel]
Responses
HTTP Code
Description
Schema
404
The datasource id does not exist
EventRepresentation
201
Created
EventRepresentation
501
Provider type does not support 'EVENT_WRITE' capability
EventRepresentation
500
Remote source server exception
EventRepresentation
Produces
  • application/json
2.6.2. Get the event for the specified identifier.
GET /datasources/{id}/event/events/{eventId}
Parameters
Type
Name
Description
Schema
Path required
id
UUID
Path required
eventId
The identifier of the event
String
Responses
HTTP Code
Description
Schema
200
Ok
EventRepresentation
501
Datasource does not support 'EVENT' capability
EventRepresentation
404
EventRepresentation
Produces
  • application/json
2.6.3. Get the event type for the specified identifier.
GET /datasources/{id}/events/type/{typeId}
Parameters
Type
Name
Description
Schema
Path required
id
UUID
Path required
typeId
The identifier of the type
String
Responses
HTTP Code
Description
Schema
200
Ok
EventTypeRepresentation
501
404
Produces
  • application/json
2.6.4. Get all event type definitions
Parameters
Type
Name
Description
Schema
Path required
id
UUID
Query
optional
continuationToken
cursor
Query
optional
size
Query
optional
sort
Sorting criteria in the format: property(,asc
Responses
HTTP Code
Description
Schema
200
Ok
CursorPagedModelEventTypeRepresentation
501
404
Produces
  • application/json
  • application/stream+json
2.6.5. Get all events after a given date
GET /datasources/{id}/events/event
Parameters
Type
Name
Description
Schema
Path required
id
UUID
Query
required
after
Events occurring after a specific date. Internet DateTime format, see RFC3339 e.g.: '2012-01-01T00:00:00Z’.
Query
optional
before
Events occurring before a specific date. Internet DateTime format, see RFC3339 e.g.: '2012-01-01T00:00:00Z’.
Query
optional
continuationToken
cursor
Query
optional
size
Query
optional
sort
Responses
HTTP Code
Description
Schema
200
Ok
CursorPagedModelEventRepresentation
501
404
Produces
  • application/json
2.6.6. Get all events based on a grouping key
GET /datasources/{id}/events/groupedevent
Parameters
Type
Name
Description
Schema
Path required
id
UUID
Query
required
groupingKey
Events belonging together are grouped by a grouping key
Query
optional
continuationToken
cursor
Query
optional
size
Query
optional
sort
Responses
HTTP Code
Description
Schema
200
Ok
501
404
Produces
  • application/json
2.6.7. Get the field for the specified identifier.
GET /datasources/{id}/events/field/{fieldId}
Parameters
Type
Name
Description
Schema
Path required
id
The identifier for the datasource
UUID
Path required
fieldId
The identifier for the field
String
Responses
HTTP Code
Description
Schema
200
Ok
EventFieldRepresentation
501
404
Produces
  • application/json
2.6.8. Get all field definitions
Parameters
Type
Name
Description
Schema
Path required
id
UUID
Query
optional
continuationToken
cursor
Query
optional
size
Query
optional
sort
Responses
HTTP Code
Description
Schema
200
Ok
CursorPagedModelEventFieldRepresentation
501
404
Produces
  • application/json
2.7. ImportedTimeSeries
2.7.1. Delete an imported time series.
DELETE /imported/timeseries/{id}
Parameters
Type
Name
Description
Schema
Path required
id
The identifier of the imported time series
UUID
Responses
HTTP Code
Description
Schema
204
No content
404
2.7.2. Delete all imported time series.
Parameters
Type Name Description Schema
Responses
HTTP Code
Description
Schema
204
No content
404
2.7.3. Get the imported time series by specified id.
GET /imported/timeseries/{id}
Parameters
Type
Name
Description
Schema
Path required
id
UUID
Responses
HTTP Code
Description
Schema
200
Ok
ImportedTimeSeriesRepresentation
404
Produces
  • application/json
2.7.4. Search the imported time series.
Parameters
Type
Name
Description
Schema
Query
optional
page
Query
optional
size
Query
optional
sort
Responses
HTTP Code
Description
Schema
200
Ok
PagedModelImportedTimeSeriesRepresentation
Produces
  • application/json
2.7.5. Imports time series from a csv file
POST /imported/timeseries
Parameters
Responses
HTTP Code
Description
Schema
422
Validation error
List[[NotImportedTimeSeries]]
204
Valid
400
Bad Request
200
OK
2.8. LegacyTimeSeries
2.8.1. Get the timeseries definition for the specified id
GET /legacy-timeseries/{id}
Parameters
Type
Name
Description
Schema
Path required
id
The identifier of the timeseries definition
UUID
Query
optional
fetchStates
Should fetch states
Responses
HTTP Code
Description
Schema
200
Ok
LegacyTagDetailsModel
404
Produces
  • application/json
2.8.2. Get timeseries definition accessibility details.
GET /legacy-timeseries/accessibility
Parameters
Type
Name
Description
Schema
Query
required
tagName
The name of the timeseries definition
Responses
HTTP Code
Description
Schema
200
Ok
LegacyAccessibilityModel
404
Produces
  • application/json
2.8.3. Get the timeseries definition by name query parameter.
Parameters
Type
Name
Description
Schema
Query
required
tagName
Query
optional
fetchStates
Should fetch states
Responses
HTTP Code
Description
Schema
200
Ok
404
Produces
  • application/json
2.8.4. Get all states of the timeseries definition by id query parameter.
GET /legacy-timeseries/{id}/states
Parameters
Type
Name
Description
Schema
Path required
id
The id of the timeseries definition
String
Responses
HTTP Code
Description
Schema
200
Ok
List[[LegacyStateModel]]
404
Produces
  • application/json
2.9. MetricsController
GET /datasources/{id}/metrics
===== Parameters
Type
Name
Description
Schema
Path required
id
UUID
===== Responses
HTTP Code
Description
Schema
200
OK
MetricRepresentation
===== Produces
  • application/json
=== Providers
===== Parameters
===== Responses
HTTP Code
Description
Schema
200
Ok
List[[ProviderMetaDataRepresentation]]
===== Produces
  • application/json
==== Get a provider and its metadata GET /providers/{name}
===== Parameters
Type
Name
Description
Schema
Path required
name
String
===== Responses
HTTP Code
Description
Schema
200
Ok
===== Produces
  • application/json
=== TimeSeries
==== EXPERIMENTAL - basic search POST /timeseries/basicsearch
===== Parameters
Type
Name
Description
Schema
Body
required
BasicSearchRequest
[BasicSearchRequest]
===== Responses
HTTP Code
Description
Schema
200
OK
CollectionModelTimeSeriesDefinitionRepresentation
===== Produces
  • application/json
==== EXPERIMENTAL - advanced search POST /timeseries/advancedsearch
===== Parameters
Type
Name
Description
Schema
Body
required
AdvancedSearchRequest
[AdvancedSearchRequest]
===== Responses
HTTP Code
Description
Schema
200
OK
===== Produces
  • application/json
==== Search the time series definition by name and description patterns GET /timeseries/advanced
===== Parameters
Type
Name
Description
Schema
Query
optional
nameSearchPattern
Pattern to search time series definitions by name.
Query
optional
descriptionSearchPattern
Pattern to search time series definitions by description.
Query
optional
historians
Query
optional
page
Query
optional
size
Query
optional
sort
===== Responses
HTTP Code
Description
Schema
200
Ok
PagedModelTimeSeriesDefinitionRepresentation
===== Produces
  • application/json
==== Check whether the logged in user is allowed to read the time series. GET /timeseries/{id}/accessibility
===== Parameters
Type
Name
Description
Schema
Path required
id
The identifier of the time series definition
UUID
===== Responses
HTTP Code
Description
Schema
200
Ok
String
===== Produces
  • application/json
==== Create a new time series definition. POST /timeseries
===== Parameters
Type
Name
Description
Schema
Body
required
TimeSeriesDefinitionModel
[TimeSeriesDefinitionModel]
===== Responses
HTTP Code
Description
Schema
400
Bad Request
201
Created
===== Produces
  • application/json
==== Delete time series definitions. DELETE /timeseries/{ids}
===== Parameters
Type
Name
Description
Schema
Path required
ids
The id's of the time series
UUID
===== Responses
HTTP Code
Description
Schema
204
No content
404
==== Deletes a time series definition by datasource id and external id DELETE /timeseries
===== Parameters
Type
Name
Description
Schema
Query
required
datasourceId
Query
required
externalId
The external identifier of the time series.
===== Responses
HTTP Code
Description
Schema
204
No content
404
==== Get the value mapping for the specified time series, string or int value. If stringValue is present and autocreate=true - new value mapping entry will be created GET /timeseries/{id}/valuemapping
===== Parameters
Type
Name
Description
Schema
Path required
id
UUID
Query
optional
intValue
Int value of value mapping
Query
optional
stringValue
String value of value mapping
Query
optional
autocreate
Create new value mapping if string value is not present for requested time series definition
===== Responses
HTTP Code
Description
Schema
200
Ok
TimeSeriesValueMappingRepresesentation
404
===== Produces
  • application/json
==== Get the time series definition for the specified identifier. GET /timeseries/{id}
===== Parameters
Type
Name
Description
Schema
Path required
id
UUID
===== Responses
HTTP Code
Description
Schema
200
Ok
404
===== Produces
  • application/json
==== Get the time series definition for the specified identifier with dependency tree. GET /timeseries/{id}/dependency-tree
===== Parameters
Type
Name
Description
Schema
Path required
id
UUID
===== Responses
HTTP Code
Description
Schema
200
Ok
TimeSeriesDependencyTreeDefinitionRepresentation
404
===== Produces
  • application/json
==== Get the time series definition by external id for the specified identifier with dependency tree. GET /timeseries/dependency-tree
===== Parameters
Type
Name
Description
Schema
Query
required
datasourceId
The identifier of the datasource.
Query
required
externalId
The external identifier of the time series definition
Query
optional
deletedAllowed
Allow deleted time series definition
===== Responses
HTTP Code
Description
Schema
200
Ok
404
===== Produces
  • application/json
==== Get the time series definitions relations. GET /timeseries/relations
===== Parameters
Type
Name
Description
Schema
Query
optional
page
Query
optional
size
Query
optional
sort
===== Responses
HTTP Code
Description
Schema
200
Ok
PagedModelTimeSeriesRelationRepresentation
===== Produces
  • application/json
==== Get all digital states for the specified time series. GET /timeseries/{id}/valuesmapping
===== Parameters
Type
Name
Description
Schema
Path required
id
UUID
Query
optional
page
Query
optional
size
Query
optional
sort
===== Responses
HTTP Code
Description
Schema
200
Ok
PagedModelTimeSeriesValueMappingRepresesentation
404
===== Produces
  • application/json
==== Get the digital states by intValue for the specified time series. POST /timeseries/{id}/valuesmapping
===== Parameters
Type
Name
Description
Schema
Path required
id
UUID
Body
required
ValueMappingRequestModel
Model containing the identifiers of the value mappings in a int list
[ValueMappingRequestModel]
===== Responses
HTTP Code
Description
Schema
200
Ok
List[[TimeSeriesValueMappingRepresesentation]]
404
===== Produces
  • application/json
==== Effective index horizon GET /timeseries/indexhorizon
===== Parameters
===== Responses
HTTP Code
Description
Schema
200
OK
IndexHorizonRepresentation
===== Produces
  • application/json
==== Search the time series definition with rsql. POST /timeseries/search
===== Parameters
Type
Name
Description
Schema
Query
optional
deletedAllowed
True if deleted time series should be returned
Query
optional
page
Query
optional
size
Query
optional
sort
[String]
Body
required
RsqlRequest
===== Responses
HTTP Code
Description
Schema
200
OK
===== Produces
  • application/json
==== Search the time series definitions GET /timeseries
===== Parameters
Type
Name
Description
Schema
Query
optional
searchPattern
Pattern to search time series definitions. Cannot be used at the same time as name parameter.
Query
optional
name
The name of the time series definitions to search for. Cannot be used at the same time as searchPattern parameter.
Query
optional
deletedAllowed
Query
optional
page
Query
optional
size
Query
optional
sort
===== Responses
HTTP Code
Description
Schema
200
Ok
===== Produces
  • application/json
==== Search digital states for the specified time series with rsql. POST /timeseries/{id}/valuesmapping/search
===== Parameters
Type
Name
Description
Schema
Path required
id
UUID
Query
optional
page
Query
optional
size
Query
optional
sort
[String]
Body
required
RsqlRequest
===== Responses
HTTP Code
Description
Schema
200
Ok
404
===== Produces
  • application/json
==== Update a time series definition. PUT /timeseries/{id}
===== Parameters
Type
Name
Description
Schema
Path required
id
UUID
Body
required
===== Responses
HTTP Code
Description
Schema
200
Ok
400
Bad Request
404
201
Created
===== Produces
  • application/json
==== Update a time series definition by datasource id and external id. PUT /timeseries
===== Parameters
Type
Name
Description
Schema
Query
required
datasourceId
Query
required
externalId
Body
required
===== Responses
HTTP Code
Description
Schema
200
Ok
400
Bad Request
404
201
Created
===== Produces
  • application/json
== Models
=== AdvancedSearchRequest
Field Name Required Type Description Format
name
String
description
String
datasources
List of [UUID]
uuid
=== Asset
identifier
String
parentIdentifier
String
type
String
template
Template
data
Data
name
String
description
String
=== AssetRepresentation
identifier
String
parentIdentifier
String
type
String
children
List of [Asset]
template
Template
data
oneOf<DataReferenceData,NumericData,StringArrayData,StringData>
name
String
description
String
links
List of [Link]
=== BasicSearchRequest
query
X
String
datasources
List of [UUID]
uuid
=== BoolCapabilityProperty
name
String
label
String
type
String
Enum: SINGLE_LINE, MULTI_LINE, BOOL, DROPDOWN, BOOL_GROUP,
capabilities
List of [string]
Enum:
required
Boolean
=== BoolGroupCapabilityProperty
name
String
label
String
type
String
capabilities
List of [string]
Enum:
required
Boolean
groupType
String
=== BoolGroupCapabilityPropertyAllOf
groupType
String
=== CapabilitiesModel
canChangeInterpolationType
Boolean
=== CapabilityProperty
name
String
label
String
type
String
capabilities
List of [string]
Enum:
required
Boolean
=== CollectionModelTimeSeriesDefinitionRepresentation
links
List of [Link]
content
List of [TimeSeriesDefinitionRepresentation]
=== Component
identifier
String
type
String
Enum: TAG, ATTRIBUTE, ASSET,
=== ComponentModel
identifier
String
type
String
=== ConfigurationItemRepresentation
name
String
value
String
description
String
createdBy
String
createOn
Date
date-time
modifiedBy
String
modifiedOn
Date
date-time
links
List of [Link]
=== ConnectionStatus
healthy
Boolean
=== ConnectionTest
networkLatency
Long
int64
connectionSpeed
Long
int64
retriesCount
Long
int64
=== ConnectorModel
name
X
String
description
String
host
X
String
username
String
password
String
maxConnections
Integer
int32
=== ConnectorRepresentation
name
String
description
String
status
String
Enum: ACTIVE, DELETED, SYNC_IN_PROGRESS, SYNC_ERROR, NOT_SYNCABLE,
statusDescription
String
host
String
username
String
password
String
syncedBy
String
syncedOn
Date
date-time
createdBy
String
createOn
Date
date-time
modifiedBy
String
modifiedOn
Date
date-time
connectorId
UUID
uuid
links
List of [Link]
=== ContextChange
changedItem
ContextItem
changeType
String
Enum: ADD, MODIFY, DELETE,
=== ContextItem
identifier
String
name
String
description
String
type
ContextTypeItem
events
List of [Event]
components
List of [Component]
fields
List of [map]
keywords
List of [string]
lastModifiedDate
String
errors
List of [Error]
=== ContextItemRepresentation
identifier
String
name
String
description
String
type
ContextTypeItemModel
events
List of [EventModel]
components
List of [ComponentModel]
fields
List of [map]
keywords
List of [string]
lastModifiedDate
String
errors
List of [ErrorModel]
links
List of [Link]
=== ContextTypeItem
identifier
String
name
String
workflowIdentifier
String
=== ContextTypeItemModel
identifier
String
name
String
workflowIdentifier
String
=== ContextTypeRepresentation
identifier
String
name
String
workflow
IdentifierModel
color
String
fields
List of [IdentifierModel]
links
List of [Link]
=== CursorPageMetadata
=== CursorPagedModelEventFieldRepresentation
links
List of [Link]
content
List of [EventFieldRepresentation]
page
CursorPageMetadata
=== CursorPagedModelEventRepresentation
links
List of [Link]
content
List of [EventRepresentation]
page
CursorPageMetadata
=== CursorPagedModelEventTypeRepresentation
links
List of [Link]
content
List of [EventTypeRepresentation]
page
CursorPageMetadata
=== CursorPagedResourcesContextChange
content
List of [ContextChange]
nextPage
String
=== Data
type
String
Enum: DATA_REFERENCE, STRING_ARRAY, NUMERIC, STRING,
value
Object
=== DataReferenceData
type
String
value
String
=== DataReferenceDataAllOf
value
String
=== DatasourceModel
type
X
String
name
X
String
description
String
connectorId
UUID
uuid
datasourceId
UUID
uuid
maxConnections
Integer
int32
onlySupportsRawValues
Boolean
maxPlotPeriodInDays
Integer
int32
capabilityTypes
Set of [string]
providerTypeProperties
Set of [ProviderTypePropertyModel]
=== DatasourceRepresentation
type
String
name
String
description
String
maxConnections
Integer
int32
Boolean
status
String
statusDescription
String
syncedBy
String
syncedOn
Date
date-time
createdBy
String
createOn
Date
date-time
modifiedBy
String
modifiedOn
Date
date-time
indexingGranularity
String
maxPlotPeriodInDays
Integer
int32
capabilityTypes
Set of [string]
Enum:
connectorId
UUID
uuid
Set of [ProviderTypePropertyRepresentation]
builtin
Boolean
datasourceId
UUID
uuid
links
List of [Link]
=== Dependency
identifier
UUID
uuid
externalIdentifier
String
datasourceIdentifier
UUID
uuid
datasourceType
String
dependents
List of [Dependency]
dependencies
name
String
label
String
type
String
capabilities
List of [string]
Enum:
required
Boolean
options
List of [DropDownOption]
options
key
String
value
String
=== Error
type
String
key
String
message
String
=== ErrorModel
type
String
key
String
message
String
=== Event
identifier
String
occurred
String
state
String
=== EventFieldRepresentation
identifier
String
name
String
type
String
Enum: STRING, NUMERIC, ENUMERATION,
placeholder
String
options
List of [string]
links
List of [Link]
=== EventModel
identifier
String
name
String
description
String
type
EventTypeModel
state
String
occurredAt
Date
date-time
modifiedAt
Date
date-time
components
fields
List of [map]
keywords
List of [string]
errors
groupingKey
String
=== EventRepresentation
identifier
String
name
String
description
String
type
EventType
state
String
occurredAt
Date
date-time
modifiedAt
Date
date-time
components
List of [Component]
fields
List of [map]
keywords
List of [string]
errors
List of [Error]
groupingKey
String
links
List of [Link]
=== EventType
identifier
String
name
String
color
String
startState
String
endState
String
states
List of [string]
fields
List of [Identifier]
=== EventTypeModel
identifier
String
name
String
color
String
startState
String
endState
String
states
List of [string]
fields
write
Boolean
=== EventTypeRepresentation
identifier
String
name
String
color
String
startState
String
endState
String
states
List of [string]
fields
links
List of [Link]
=== FieldRepresentation
identifier
String
name
String
type
String
placeholder
String
options
List of [string]
links
List of [Link]
=== HistorianDetailsModel
dbId
String
name
String
server
String
=== Identifier
identifier
String
=== IdentifierModel
identifier
String
=== ImportedTimeSeriesRepresentation
identifier
UUID
uuid
name
String
description
String
unitOfMeasurement
String
timeSeriesType
String
Enum: ANALOG, DIGITAL, DISCRETE, STRING,
createOn
Date
date-time
links
List of [Link]
=== IndexHorizonRepresentation
links
List of [Link]
horizon
Date
date-time
=== LegacyAccessibilityModel
accessibility
String
Enum: accessible, denied, deleted, undefined,
=== LegacyStateModel
Name
String
Code
Integer
int32
Offset
Integer
int32
=== LegacyTagDetailsModel
id
String
name
String
description
String
interpolationType
String
units
String
source
String
startDate
Date
date-time
endDate
Date
date-time
deleted
Boolean
capabilities
CapabilitiesModel
historian
Type
String
States
List of [LegacyStateModel]
type
String
Name
String
TagName
String
=== MetricRepresentation
datasourceId
UUID
uuid
datasourceIndex95pInMillis
Long
int64
datasourceIndex50pInMillis
Long
int64
datasourcePlot95pInMillis
Long
int64
datasourcePlot50pInMillis
Long
int64
datasourceSync95pInMillis
Long
int64
datasourceSync50pInMillis
Long
int64
connectorId
UUID
uuid
connectorIndex95pInMillis
Long
int64
connectorIndex50pInMillis
Long
int64
connectorPlot95pInMillis
Long
int64
connectorPlot50pInMillis
Long
int64
connectorSync50pInMillis
Long
int64
connectorSync95pInMillis
Long
int64
links
List of [Link]
=== MultiLineCapabilityProperty
name
String
label
String
type
String
capabilities
List of [string]
Enum:
required
Boolean
placeholder
String
=== MultiLineCapabilityPropertyAllOf
placeholder
String
=== NotImportedTimeSeries
tagName
String
reason
String
details
Map of [string]
=== NumericData
type
String
value
BigDecimal
=== NumericDataAllOf
value
BigDecimal
=== PageMetadata
=== PagedModelConfigurationItemRepresentation
links
List of [Link]
content
List of [ConfigurationItemRepresentation]
page
PageMetadata
=== PagedModelConnectorRepresentation
links
List of [Link]
content
List of [ConnectorRepresentation]
page
PageMetadata
=== PagedModelContextItemRepresentation
links
List of [Link]
content
List of [ContextItemRepresentation]
page
PageMetadata
=== PagedModelContextTypeRepresentation
links
List of [Link]
content
List of [ContextTypeRepresentation]
page
PageMetadata
=== PagedModelDatasourceRepresentation
links
List of [Link]
content
List of [DatasourceRepresentation]
page
PageMetadata
=== PagedModelFieldRepresentation
links
List of [Link]
content
List of [FieldRepresentation]
page
PageMetadata
=== PagedModelImportedTimeSeriesRepresentation
links
List of [Link]
content
List of [ImportedTimeSeriesRepresentation]
page
PageMetadata
=== PagedModelTimeSeriesDefinitionRepresentation
links
List of [Link]
content
page
PageMetadata
=== PagedModelTimeSeriesRelationRepresentation
links
List of [Link]
content
List of [TimeSeriesRelationRepresentation]
page
PageMetadata
=== PagedModelTimeSeriesValueMappingRepresesentation
links
List of [Link]
content
List of [TimeSeriesValueMappingRepresesentation]
page
PageMetadata
=== PagedModelWorkflowRepresentation
links
List of [Link]
content
List of [WorkflowRepresentation]
page
PageMetadata
=== ProviderMetaDataRepresentation
name
String
label
String
experimental
Boolean
connectors
List of [string]
capabilities
Set of [string]
Enum:
properties
List of BoolGroupCapabilityProperty,DropDownCapabilityProperty,MultiLineCapabilityProperty,SingleLineCapabilityProperty>
links
List of [Link]
=== ProviderTypePropertyModel
name
X
String
value
String
encrypted
Boolean
=== ProviderTypePropertyRepresentation
name
String
value
String
encrypted
Boolean
links
List of [Link]
=== RsqlRequest
query
X
String
=== SingleLineCapabilityProperty
name
String
label
String
type
String
capabilities
List of [string]
Enum:
required
Boolean
placeholder
String
encrypted
Boolean
=== SingleLineCapabilityPropertyAllOf
placeholder
String
encrypted
Boolean
=== StringArrayData
type
String
value
List of [string]
=== StringArrayDataAllOf
value
List of [string]
=== StringData
type
String
value
String
=== Template
identifier
String
name
String
=== TimeSeriesDefinitionModel
id
UUID
uuid
datasourceId
X
UUID
uuid
externalId
String
name
X
String
description
String
type
X
String
dependentTimeSeriesDefinitions
List of [UUID]
uuid
=== TimeSeriesDefinitionRepresentation
datasourceId
UUID
uuid
ownerId
String
externalId
String
name
String
description
String
type
String
units
String
interpolationType
String
datasourceType
String
deleted
Boolean
plotDataUrl
String
indexDataUrl
String
links
List of [Link]
id
UUID
uuid
=== TimeSeriesDependencyTreeDefinitionRepresentation
dependents
dependencies
links
List of [Link]
=== TimeSeriesRelationRepresentation
timeSeriesId
UUID
uuid
timeSeriesExternalId
String
timeSeriesDatasourceId
UUID
uuid
relationTimeSeriesId
UUID
uuid
relationTimeSeriesExternalId
String
relationTimeSeriesDatasourceId
UUID
uuid
links
List of [Link]
=== TimeSeriesValueMappingRepresesentation
timeSeriesId
UUID
uuid
stringValue
String
intValue
Integer
int32
links
List of [Link]
=== ValueMappingRequestModel
intValues
List of [integer]
int32
=== VersionInfo
version
String
=== WorkflowRepresentation
identifier
String
name
String
startState
String
endState
String
states
List of [string]
links
List of [Link]
